johns's avatar
johns
Ret. Employee
Jul 11, 2006
Persistence using Source IP and PORT
I have a requirement where clients log into a terminal server farm and initiate https requests to VIP on BIG-IP, and need to persist users based on their source IP and PORT. Currently, it is not possible to off load SSL to BIG-IP and using the Source IP option, there is a fare amount of "clumping".
Is there any plan to add SourcePort (with SourceIP) as a parameter to persistence method, or would it be possible by parsing IP header? (using Universal Persistence)
Thanks.
John
  • Hi Joey,
    since v10, I wouldn't recommend to use
    persist UIE "[IP::client_addr]:[TCP::remote_port]"
    anymore.
    Using a CARP based algorythm for this specific scenario would be far more elegant now, since CARP doesn't need to store a session table record for each single client_ip:port combination and doesn't have to remember any timeouts.
    when CLIENT_ACCEPTED {
        persist carp "[IP::client_addr]:[TCP::remote_port]"
        pool xyz_pool
    Cheers, Kai
