genseek_32178
May 15, 2012Persistence Not Working
For the following VIP, persistence is not working..
virtual syz-443
pool syzpl-443
destination 20.20.12.25:https
ip protocol tcp
vlans 25 enable
profiles tcp-profile
persist persist-source-addr-syz
http://20.20.12.25/lb/on.txt is giving different server every minute when persistence is set to 600 sec.
any help here would be great on what is causing this?
genseek
- MVA
Just taking a quick look at your posted config, it seems as though your destination is https but the URL you posted is http. Is there another Virtual Server using http without persistence? - genseek_32178
yes there is another VS that is using http with persistence. - genseek_32178
i noticed the following also..
persist-source-addr-syz - IS the custom profile...AND
persist-default-syz - Is the default profile
Although, the persist-source-addr-syz is set for timeout vlaue of 600,
the persist-default-syz profile seems to be having no setting of timeout value
b profile persist-default-syz list
defaults from sourceaddr
As no timeout setting is defined the custom profil persist-source-addr-syz , must be inheriting timeout settings from the parent profile.
and therefore persistence is not sticking till 600 secs.
Could this be the reason? - genseek_32178
nitass, any updates? - genseek_32178
the working VIP1 is runing on 10.2 and non-working VIP2 is running on 9.4
