Enable or disable acceleration using a cookie iApp
Problem this snippet solves:
This F5 contributed, release candidate iApp template provides a (temporary) way of quickly enabling/disabling Web Acceleration on a per user session basis, using a browser cookie. This can be useful for debugging or benchmarking purposes.
The template creates a new virtual server using the same IP address as the existing virtual server for which you want to toggle acceleration, but on a different service port. This new virtual server can set and delete the accel-disable cookie when you browse to it.
This version of this iApp template is now found on downloads.f5.com in the iApp templates package. For more information, see the inline help and the Help tab in the template.
Code :
46229
Published Mar 11, 2015
Version 1.0Joe_Jordan
Ret. Employee
Joined November 15, 2004
