Frankx's avatar
Frankx
Jan 31, 2017
Persistence iRule for Airwatch
I've been asked to write an iRule using CARP persistence and based on awcmsessionid. Found this on DevCentral and it was all I could find was wondering if anyone can tell if this works and/or have an iRule that does work. Thanks, Frank.
when HTTP_RESPONSE { Check the awcmsessionid header exists if { [HTTP::header exists "awcmsessionid"] } {
If it does, check it has a usable value
if { [HTTP::header value "awcmsessionid"] != "" } {
  If it does, use it to create a persistence record
  persist add uie [HTTP::header value "awcmsessionid"] 1800
else {
  log local0. "The awcmsessionid HTTP header was found but is null"
  No luck then, will need to rely on request query string if we can
If no header found log local0. "The awcmsessionid HTTP header was not found" }
when HTTP_REQUEST { Check the awcmsessionid header exists if { [HTTP::header exists "awcmsessionid"] } {
  If it does, use it to do a persistence lookup
  If you need to select a pool, do so here, before we persist
  persist uie [HTTP::header value "awcmsessionid"] 1800
  exit here to ensure we don't do two persistence lookups
  return
else {
No header so lets use the HTTP query instead, if we can Check the right string exists if { [string tolower [HTTP::query ]] contains "awcmsessionid" } {
The required query string is there, let's get it's value
We'll find awcmsessionid, move one to the right (the =)
and store data to the end of the query in our variable
set querystring [findstr [HTTP::query] "awcmsessionid" "1"]
Lets check its not null
if { $querystring != "" } {
  persist uie $querystring 1800
else {
  log local0. "No header or relevant query string found - can't persist"
