Persistence Cookie Random Values
Our QA department used to test servers by using Fiddler to override the encrypted persistence cookie value....this was in 10.2.4. They would hit the VIP and go through all the servers in the pool and use Fiddler to extract their encrypted persistence cookie value. That encrypted persistence cookie value would never change. The value was the same day in and day out. We recently upgraded to 11.5.2HF1 and now it seems that there is some randomness to the encrypted persistence cookie value. The encrypted persistence cookie value it hands out for a back end server does not stay the same. If I wait thirty minutes and hit the same VIP, the encrypted persistence cookie value will not be the same. I know what server I am hitting by an identifier at the bottom of the web page. I then look in Fiddler to see what the cookie value is and it does not match the one from thirty minutes earlier. I want to make it clear that cookie persistence is working. So nothing is "broken" except for QA not being able to override cookies and force the connection to the desired server. Is this working as intended?
- sfuerst_116779Historic F5 Account
If the persistence cookie is set up to be encrypted, then a random IV is used to do the encryption. (The IV is included in the base-64 encrypted result, allowing it to be decrypted again.) This means that the same unencrypted cookie can encrypt to many different results as the IVs can differ.
The reason for this is so that different clients of the website will get different persistence cookies. Cookies cannot be compared to determine any information about what the cookie originally was. (A simpler scheme would encrypt identical cookies to the same encrypted result. This would allow two users to see if they got the same encrypted = same unencrypted cookie, which would be a small information leak.)
- JMC-TN_184986
I have been searching but have not found any F5 documentation that explains this process. Do you happen to know of any that you could link? Thanks
This Wikipedia article describes how an IV works: https://en.wikipedia.org/wiki/Block_cipher_mode_of_operation
Unfortunately, I don't think the exact algorithm used is documented anywhere public.
