syedimam_147051's avatar
syedimam_147051
Feb 26, 2016
Passive FTP failing, F5 send TCP RST after receiving Entering Passive mode from server
Hi Pretty standard setup Passive FTP Control port 10021 Data ports 50251-50500
Configuration
VIP: 192.168.152.8 (Open for all ports) Auto SNAT (interface and pool members on same vlan) Profile Basic FTP Profile Basic TCP client/server profile
Self IP: 10.57.152.6 Pool: 10.57.152.6 (open for all ports)
Problem:
With basic FTP profile, F5 send TCP RST as soon as it receives response of PASV request from server that it entering into passive mode.
If we aremove FTP profile and use basic TCP Profile, it works fine.
TCP Reset from F5 self ip to backend
TCP Reset from F5 to Client
Passive IP: F5 VIP (192.168.152.8) Passive Port 50252 Passive IP NAT: True
Thanks Syed
  • Self IP: 10.57.152.6 Pool: 10.57.152.6 (open for all ports)
    pool is 10.57.152.7, isn't it?
    can you post both client-side and server-side trace?
    e.g.
     tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.cap host 192.168.152.8 or host 10.57.152.7 -v
  • Hi Sorry, it was a typo. Indeed, .6 is floating IP to carry traffic and .7 is the Pool. Results attached. I have tested this in lab as well and results are same. Server listning on ports 5000-6000, with only TCP profile traffic works fine. With FTP profile, F5 sending RST after getting entering into passive mode from server. Also tried following iRule and exactly same results. when SERVER_CONNECTED { FTP::port 5000 5999 } F5 to Server
    Client to F5
  • Try creating a non-default ftp profile and allow ANY data port.
    Per default, only port 20 is allowed:
        list ltm profile ftp /Common/ftp all-properties
       ltm profile ftp /Common/ftp {
           app-service none
           defaults-from none
           description none
           inherit-parent-profile disabled
           log-profile none
           log-publisher none
           partition Common
           --> port ftp-data <--
           security disabled
           translate-extended enabled
    try using this instead:
    ltm profile ftp ftp_dataport_any {
        app-service none
        defaults-from /Common/ftp
        --> port any <--
    With this profile, you also should not need to enable the virtual on any port, but on the desired ftp-control port only (in your case 10021).
    HTH Martin
  • PROD environment works fine with iRule but it is failing in the lab. I checked and server ports are in same range.
    have you captured packet? what did you see there?
