Page trying to load scripts from unauthenticated sources
We have recently hosted a web application on F%. The application is working fine but the page is not displayed until we select the option of allowing "Page trying to load scripts from unauthenticated sources". What might be the reason behind this message. Can it be a SSL cert error?
Thanks,
Sekhar
- cjunior
Nacreous
are you doing ssl offload? maybe the problem is http resources under https site.
https://support.google.com/chrome/answer/1342714?hl=en
so, you may need to rewrite the contents of html with a rewrite profile or irule, e.g. []
- Sekhar
Hi All,
I was able to fix the error using the stream profile and using the irule assocaited with stream profile. You can find the irule in the following link.
https://devcentral.f5.com/wiki/iRules.HTTPS-offload-rewriting.ashx
Thanks, Sekhar
- joelmhai_217900
Hi I have a Apache Web Server that run on http:// could we able to disable the authenticated script while loading? how to set up the settings. thanks!
