ray_1882_110233's avatar
ray_1882_110233
Mar 06, 2011
Packet Filtering for block ICMP Traffic
Hi All,
In my network design, it consists of 3 network segment which is VLAN_Internal, VLAN_ISP1, VLAN_ISP2.
So i created 2 packet filter rules to block the ICMP from external network (VLAN_ISP1 & VLAN_ISP2) and it works perfectly.
However, when i ping from the internal segment (VLAN_Internal), i found that the ping packets is intermittent drops, but when i "disable" the packet filters features on F5, and the ping become smooth..
Any idea wat will causes this problem?
thanks..
Best Regards,
Ray
  • hoolio's avatar
    hoolio
    Hi Ray,
    Check your other post for a suggestion:
    http://devcentral.f5.com/Forums/tabid/1082223/asg/60/showtab/groupforums/aff/73/aft/1177178/afv/topic/Default.aspx
    Aaron
