Anzine321
Cirrus
Apr 02, 2023only actrive blade snmp work not stanby on viprion with 4 blade
i have configuration snmp for monitoring f5 resource and we using vcmp viprion and have 4 blade, but the problem is only active blade snmp work and standby slot not work any suggestion how to reso...
Paulius
MVP
Apr 12, 2023Anzine321 I'm not intimately familiar with this but I do know that in some instances SNMP will only work on the active blade of certain devices, this is even outside of F5, so you might have to configure your SNMP polling device to check the status of that blade but I can't see much working beyond that.
