one rewrite url works and another does not.
Hello
I have written an iRule script to rewrite a url based on a condition-
http://intfilings.abc.gov/navigator_icm/?desktop=xyz should rewrite to
http://intfilings.abc.gov/EFilingWeb/ManageTicklers should rewrite to
Here is the iRule script- When HTTP_REQUEST { if { [HTTP::header host] equals "intfilings.abc.gov" && [HTTP::header uri] starts_with "/navigator_icm" } { HTTP::header replace Host "server1.ct.gov:9081" } if { [HTTP::header host] equals "intfilings.abc.gov" && [HTTP::header uri] starts_with "/EFilingWeb" } { HTTP::header replace Host "server2.ct.gov:9080" }
Whichever URL i click on first works and then the other does not.
- Lee_Sutcliffe
Nacreous
You have an error in your code, [HTTP::header uri] will look for a header called 'uri', whereas I assume you mean HTTP::uri.
You are also checking for the same header twice so I've put it in one 'if' statement as well as adding a couple of lines of logging that may help troubleshooting. You also may want to consider using string tolower if this is accessed via a browser as URI is case sensitive. Please try the following.
when HTTP_REQUEST { if {[HTTP::header "Host"] equals "intfilings.abc.gov"} { if {[HTTP::uri] starts_with "/navigator_icm"} { log local0. "replacing host on URI: [HTTP::uri]" HTTP::header replace Host "server1.ct.gov" } elseif {[HTTP::uri] starts_with "/EFilingWeb"} { log local0. "replacing host on URI: [HTTP::uri]" HTTP::header replace Host "server2.ct.gov" } } }You can also perform the same functionality using LTM Traffic Policies, these are recommended for simple iRules such as these.
- youssef1
Cumulonimbus
can you try this (I dont' think it's necessary to add port in host header...):
When HTTP_REQUEST { if { [HTTP::host] equals "intfilings.abc.gov" && [HTTP::uri] starts_with "/navigator_icm" } { HTTP::header replace Host "server1.ct.gov:9081" } if { [HTTP::host] equals "intfilings.abc.gov" && [HTTP::uri] starts_with "/EFilingWeb" } { HTTP::header replace Host "server2.ct.gov:9080" } }So can you try with port in host header an without please
- stan_piron
Cumulonimbus
try this for logging (irule from Lee with logging request not matching any of 2 conditions)
when HTTP_REQUEST { if {[HTTP::host] equals "intfilings.abc.gov"} { if {[HTTP::uri] starts_with "/navigator_icm"} { log local0. "replacing host header with : server1.ct.gov on URI: [HTTP::uri]" HTTP::header replace Host "server1.ct.gov" } elseif {[HTTP::uri] starts_with "/EFilingWeb"} { log local0. "replacing host header with : server2.ct.gov on URI: [HTTP::uri]" HTTP::header replace Host "server2.ct.gov" } else { log local0. "Unchanged host header on URI: [HTTP::uri]" } } }
