El_Jefe's avatar
El_Jefe
Aug 02, 2011
Odd Issue
OK, I switched our main production website to behind the F5 LTM last night. I had the profile set for compression and caching. Initial tests last night went great. This morning, The page would not load completely, and it appeared to be a caching problem. This is an Oracle 11G ADF App, if that helps. I turned off caching, and it started working again. Is there any documentation on tuning the cache for the LTM or something like that?
Thanks!
Jeff
  • hoolio's avatar
    hoolio
    Hi Jeff,
    I suggest opening a case with F5 Support on this issue. They'll be able to help you troubleshoot the issue.
    Aaron
  • Hamish's avatar
    Hamish
    For ramcache, pages are cached by default. Make sure youre excluding specifically any pages that you dont want cached (fixed/changed in v11 btw)
    H
