Gaurav_31719
May 15, 2012Not able to go to extenal network from BIGIP
Dear All,
I am facing an issue in BIGIP.
I have two virtual BIGIP deployed on VMware. I have two network (VLAN 74 & 86) which is connect to customer network. From VLAN 74 I am able to ping and it is showing Green in nodes but on VLAN 86 I am not able to ping and in nodes it is showing Red. If I am taking trraceroute than it drops on its own self IP.
vlan external_internet {
tag 74
interfaces tagged 1.1
vlan external_mobile {
tag 86
timeout 35
Pls help me out in this.
Thanks & Regards,
Gaurav
- Techgeeeg
Hi Gaurav,
Can you also mention the route that you have added on the LTM box???? Is the added route right one that knows both of these vlans or not???/
Regards, - smp_86112
Another thing to check is that your switchports are configured as trunked (if they are Cisco), since you are tagging the VLANs on the LTM.
