fa141_28766's avatar
fa141_28766
Aug 23, 2011
Node failover
If I have a pool with 4 nodes
Node A
Node B
Node C
Node D
If node A fails, I want it's clients to failover to Node a.
Node A if fails send clients to Node a
Node B if fails send clients to Node b
Node C if fails send clients to Node c
Node D if fails send clients to Node d
So each node has it's own static backup node.
Anyone know how to accomplish this?
Thanks,
Peter M.
  • Colin_Walker_12's avatar
    Colin_Walker_12
    Historic F5 Account
    I'm not sure I follow what Node a is vs. Node A. You mean you want to fail to a backup Node that isn't B, C, or D?
    That's certainly possible. You would just need to check the node state prior to sending a request there. This can be done with the LB:: commands pretty easily. A rudimentary example would look like:
    if {!([LB::status node 10.10.10.10] eq "up") } {
    node 10.10.10.11 80
    Colin
  • Yes Node A is one IP with Node a another. I want to force it to go to Node a versus another Node in the pool
  • How about you create 4 pools
    NodeA pool contains both nodes "A" and "a"
    NodeB pool contains both nodes "B" and "b" so on and so forth.
    Then set the high priority on node A in Pool NodeA ... so if Node A fails then it will go to node a ...
    Just my 2 cents.
