DenisG_22372's avatar
DenisG_22372
Historic F5 Account
Mar 26, 2012
Newbie needing APM help
So I have this:
Two Virtual server for SAP portal, one is the portal itself, and the other is the iView server. They both need to be accessible externally via DNS name.
When a user logs into the my.portal.com address I have it authenticating against AD and then allowing access to the portal server. The portal server then tells the client to go get their data for the frames from data.domain.com. If I open up that virtual server out to the internet without any authentication the queries work and everything is fine.
Problem is that if someone hits the data.domain.com they are hitting an internal server diretly without the f5 ensuring they are authorized via AD auth.
so I want to ahve the user auth once and have both virtual servers sharing the same access profile without prompting for ad auth twice.
Thanks for any help you can provide.
If needed I can provide a visio maybe.
