Dan_103700's avatar
Dan_103700
Mar 11, 2011
Nested Conditionals and NOT conditionals
Hi there,
I've been meaning to ask for awhile how to do nested conditionals and use a "not" operator in iRules.
I frequently end up writing iRules that look like this:
if { $foo starts_with "bar" } {
Do Nothing
pool foo_pool
Would I get the same thing with just:
if { not $foo starts_with "bar" } {
pool foo_pool
Also, is it possible to do nested conditionals... something like:
if { {$foo starts_with "bar" or $bar ends_with "foo"} and {$baz == 5} } {
And ideally, combine these 2 to get something like:
if { { {not $foo starts_with "bar"} or $bar ends_with "foo"} and {$baz == 5} } {
I guess if I take the time to learn the operator precedence and how conditional comparisons evaluate from left to right, I wouldn't need the extra nesting. Still, as a programmer, I've always found value in adding extra parenthesis to make conditional logic easier to read. Hopefully, there's some similar syntax in Irules/TCL to do this because trying to program without the extra braces/parenthesis makes my head hurt.
Thanks!
-Dan
  • hoolio's avatar
    hoolio
    Hi Dan,
    Make sure to use parentheses (not curly braces) when negating checks. Else, you'll get syntax errors or the wrong tests performed:
    if { not ($foo starts_with "bar") } {
       pool foo_pool
    Without the parens, you'd be negating $foo and then seeing if that starts with "bar".
    Aaron
  • Colin did a good overview on nested conditionals here - http://devcentral.f5.com/Tutorials/TechTips/tabid/63/articleType/ArticleView/articleId/255/iRules-101--13--Nested-Conditionals.aspx
    I personally like using "!" for not.
  • hoolio's avatar
    hoolio
    TCL operator precedence should be the same as most other languages. So the ! or not takes precedence over the starts_with string evaluation.
    http://www.tcl.tk/man/tcl8.4/TclCmd/expr.htmM6
    if { ($foo starts_with "bar" or $bar ends_with "foo") and ($baz == 5) } {
    if { ( not ($foo starts_with "bar") or $bar ends_with "foo") and $baz == 5 } {
    Aaron
  • Great info. I have a feeling I'll be cleaning up some of my messier work, come Monday. Thanks.
