Need to capture start and End timestamp
Hello Team,
Can any one suggest me regarding how to capture end user's session start time and End time in F5 VPN.
I want to know exactly how much time that particular user had maintain his session on ssl vpn.
- youssef1
Cumulonimbus
You can find this information in APM Logs.
In Report:
- Access ›› Overview : Active Reports
- Select session wanted regarding user:
You have this information:
2018-10-17 10:19:54 /Common/ap-application:Common:451dffds: Following rule 'Out' from item 'XXXX' to ending 'Allow' 2018-10-17 10:35:46 /Common/ap-application:Common:451dffds: Session deleted due to user inactivity.With this information you can estimate session duration.
hope it will help you.
regards
- youssef1
Cumulonimbus
Just for info, you have another way to see all session infomation using:
tmsh show apm access-info all-properties Display all access-info? (y/n) y Total records returned: 762 apm access-info dsds92sd { access-profile ltm_apm client-ip 1.1.1.1 egress-compressed 0 egress-raw 0 expiration-time 2018-10-17 09:33:17 ingress-compressed 0 ingress-raw 0 logon-user youssef partition Common profile-access-type all rx-bytes 5919 rx-packets 0 start-time 2018-10-17 09:18:08 status established tmm 2 tx-bytes 4385 tx-packets 0 virtual-server /Common/vs-app }You can also see all info regarding session using 'sessiondump --allkeys'. For more info see:
But in both case you can see just active session info withtout session duration... but it can help
Regards
