Kevin_Nail
Mar 08, 2011Need some help with an iRule
I have an iRule that appears to be processing correctly but does not drop my connection when it should. Please help!!
I have created 2 external data classes and to make this work, I added the US into the blocked_country data class.
Check if country code is a part of the embargoed list
log local0.debug "IRule has been triggered"
log local0.debug "Connection attempt from country [whereis [IP::client_addr] country]"
if { ([class match [whereis [IP::client_addr] country] equals blocked_country]) } {
log local0.debug "The [whereis [IP::client_addr] country] is a part of the embargoed list"
Country code matched the embargoed list. Check the IP exception list
if { ([class match [IP::client_addr] equals ip_exception])} {
log local0.debug "[IP::client_addr] Your IP was approved via the exception list"
Client IP matched the class, so allow it
drop
log local0.debug "[IP::client_addr] was NOT approved via the exception list"
log local0.debug "Dropping connection" }
else {
log local0.debug "[whereis [IP::client_addr] country] Country approved"
This is what it logs:
Mar 8 15:50:36 local/tmm debug tmm[4948]: Rule GEOIP_Final : IRule has been triggered
Mar 8 15:50:36 local/tmm debug tmm[4948]: Rule GEOIP_Final : Connection attempt from country US
Mar 8 15:50:36 local/tmm debug tmm[4948]: Rule GEOIP_Final : The US is a part of the embargoed country list
Mar 8 15:50:36 local/tmm debug tmm[4948]: Rule GEOIP_Final : x.x.x.x was NOT approved via the exception list
Mar 8 15:50:36 local/tmm debug tmm[4948]: Rule GEOIP_Final : Dropping connection
And yet, I still get the page that I should not be seeing. What have I got out of place? Should the "drop" be the very last thing?
- brianokelly_119
Hi Kevin,
When using drop, the connection is silently discarded. Can you try to use the reject command to actively reject the connection sending an RST. Also, can you post the details of your Virtual Server.
Brian - brianokelly_119
Hi Kevin,
Hi Kevin,
Brian - Kevin_Nail
The virtual server is a standard vip. Nothing special, runs on port 80... with autosnat enabled.
I changed from 'drop' to 'reject' still get the same messages in the log file and still get through. - Kevin_Nail
figured this one out....
the firefox web broswer cached the one good connection we made. After we cleared the cache, the iRule functions like I expect. Thanks for looking at this.
Kevin - brianokelly_119
Hi Kevin
Good news. Might want to change back to drop if you wish to silently drop the connections also.
Bok
