Darren_M_19965's avatar
Darren_M_19965
Jun 11, 2012
Need some direction Monitor vs iRule to determine to fail over
So, as the title and summary state, I'm looking for some direction here.
I need to know how to accomplish the following.
One can assume the following simple configuration:
OS/Hardware: 2 Windows 2003r2 servers behind an F5.
We'll call them Svr1 and Svr2. They are effectively identical.
Purpose:
The servers are transactional and receive a plain text IP request string on port 1200. Process the request and respond on the same port to the client.
Simplified Sample Request:
VALIDATEADDRESS|ADDR_LINE1-1|East Street|ADDR_LINE2-1|Nickerson Road|ADDR_LINE3-1|MA|ADDR_CITY-1|Marlborough|ADDR_COUNTRY-1|US|ADDR_ZIP-1|01752|ADDR_STATE-1|MA|SFCUSTNUM|101|AUDIT_USER|mdarren|LANGUAGE|en_US|
Result:
TRANSTYPE|VALIDATEADDRESS|ERRCODE|000000000|ADDRVALIDATE_TYPE|CSZIP|
Normally, the F5 is weighted so that Svr1 gets all the messages. However, if Svr1, the service, or the port is down I want to fail over to Svr2. Also, if for any reason I get an error code NOT equal to ERRCODE|00000000 I want to fail over as well. And, when the fail over DOES occur, I want to send an email from the F5 notifying of the fault.
So, my question is, which tool set should I use to accomplish this?
Thanks in advance,
Darren M
  • You don't necessarily need a pool monitor (a common monitor for all members). You can have one or more specific monitor(s) per member.
    In your case, define a TCP-type customised monitor for Svr1 with "recv" set to "ERRCODE|00000000" and Scr2 a genetic TCP-type monitor. Set Svr1's "priority" to 1 and Scr2's "priority" to 0 and pool's "min active members" to 1. This will give you the active(Svr1)-standby(Svr2).
    Regarding emails, I don't have experience with that, but I'd say you'd need an iRule to generate a log message that'd be translated into a customised trap. See:
    SOL3727: Configuring custom SNMP traps - http://support.f5.com/kb/en-us/solutions/public/3000/700/sol3727.html
    SOL3667: Configuring alerts to send email notifications - http://support.f5.com/kb/en-us/solutions/public/3000/600/sol3667.html
    SOL11127: Testing SNMP traps on BIG-IP (9.4.x - 11.x) - http://support.f5.com/kb/en-us/solutions/public/11000/100/sol11127.html
    also
    SOL6414: Determining which alerts are pre-configured to trigger an SNMP trap - https://support.f5.com/kb/en-us/solutions/public/6000/400/sol6414.html
  • @epaalx Thank you for your response! Looks like I have a lot of reading to do. I really do appreciate the direction and will look further into the email notification.
    Best regards,
    Darren M
