Sisay_Kidane_85's avatar
Sisay_Kidane_85
Feb 24, 2012
Need iHelp for iRule
I am creating maintenance page to post on LTM. I have followed few example but I am almost to the finish line with one last problem where the page is showing empty.
Here the example I use:
http://devcentral.f5.com/wiki/irule...epage.ashx
http://devcentral.f5.com/Community/...fault.aspx
When I force the need to be down by creating to monitor bad port which LTM to show to unknown state. LTM suppose to go Maintenance page but is showing blank screen.
I am new to LTM and I have tried to my best I can't figure out where the problem.
I appreciate in advance.
class maint_index_html_class {
"filename" { "/var/class/maint.index.html.class" }
rule Maintenancehtml {
if {[active_members Pool_192.168.12.110.SN01138] < 1} {
HTTP::respond 200 content [lindex $::maint_index_html_class 0] "Content-Type" "image/png"
HTTP::respond 200 [class element -value 0 maint_index_html_class]
log local0. "Maintenance Page has been issued due to pool members not active"
[username@F5:Active] log more /var/class/maint.index.html.class
"key" :="Maintenance page
Sorry! This site is down for maintenance."
Feb 24 07:08:50 local/tmm1 info tmm1[4996]: Rule Maintenancehtml : Maintenance Page has been issued due to pool members not active
  • hoolio's avatar
    hoolio
    Hi Sisay,
    This forum is for the old 4.x iRules. For v9-11, you can post here:
    https://devcentral.f5.com/Community/GroupDetails/tabid/1082223/asg/50/aff/5/showtab/groupforums/Default.aspx
    Are you still working on this issue? If so, which LTM version are you testing this on? The format and syntax has changed between 9.x, 10.x and 11.x.
    Aaron
