David_Landry's avatar
David_Landry
Jan 24, 2012
Need help with writing an iRule to remove jsession URI content
I've got a lovely challenge where I need to remove the jsessionid content from an URI.
https://test.com/web/tabs;jsessionid=07E052F5D
This would be on the server back to the client so I'm thinking I can use a HTTP_RESPONSE event. I just don't know the easiest way to remove that content.
Any help would be appreciated :)
  • not sure if i understand correctly. anyway, i assume uri is response contact and jsessionid length is fixed. please feel free to revise.
    [root@ve1023:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:80
       ip protocol 6
       rules myrule
       profiles {
          http {}
          stream {}
          tcp {}
    [root@ve1023:Active] config  b pool foo list
    pool foo {
       members 200.200.200.101:80 {}
    [root@ve1023:Active] config  b rule myrule list
    rule myrule {
       STREAM::disable
       HTTP::header remove "Accept-Encoding"
    when HTTP_RESPONSE {
       if {[HTTP::header value Content-Type] contains "text"}{
          STREAM::expression {@;jsessionid=\w{9}@@}
          STREAM::enable
    [root@ve1023:Active] config  curl -i http://200.200.200.101/test.html
    HTTP/1.1 200 OK
    Date: Tue, 24 Jan 2012 16:02:43 GMT
    Server: Apache/2.2.3 (CentOS)
    Last-Modified: Tue, 24 Jan 2012 15:58:04 GMT
    ETag: "4183f2-a5-36565b00"
    Accept-Ranges: bytes
    Content-Length: 165
    Set-Cookie: BROWSER=MOZILLA%20INTERNET_EXPLORER%20CHROME; path=/
    Content-Type: text/html; charset=UTF-8
    https://www.google.com/
    https://www.yahoo.com/
    [root@ve1023:Active] config  curl -i http://172.28.19.79/test.html
    HTTP/1.1 200 OK
    Date: Tue, 24 Jan 2012 16:02:46 GMT
    Transfer-Encoding: chunked
  • hoolio's avatar
    hoolio
    Can you just remove it from the requested URI? If so, you can use an iRule like this:
     Check if the path contains a jsessionid
    if {[HTTP::path] contains ";jsessionid="}{
     Split the path on the jsession ID and update it to the first field
    HTTP::path [getfield [HTTP::path] ";jsessionid=" 1]
    Or if you need to hide the JSESSIONID from the client you'd need to rewrite the response content using an stream profile and STREAM::expression iRule. You could use a STREAM::expression like:
    STREAM::expression {@;[jJ][sS][eE][sS][sS][iI][oO][nN][iI][dD]=[a-zA-Z0-9]*@@}
    http://devcentral.f5.com/wiki/iRules.stream__expression.ashx
    Aaron
  • hoolio's avatar
    hoolio
    Nice one Nitass 🙂
    David, here are a couple of small suggestions:
    If the JSESSIONID is in mixed case and/or the value can be more than 9 hex characters you could use the stream expression from my example. Also, you might need to remove the JSESSIONID from redirects. If so, you can add this to Nitass's example in HTTP_RESPONSE:
     Check if response is a redirect and the Location header has a jsessionid
    if {[HTTP::is_redirect] and [HTTP::header Location] contains ";jsessionid="}{
     Remove ;jsessionid= up until a ? which starts the query string
    HTTP::header replace [string map [list [findstr [string tolower [HTTP::header Location]] ";jsessionid=" 12 "?"] ""] [HTTP::header Location]]
    Aaron
  • Ok great thanks guys :). I'll give those a try this week. The concern is they don't want any JSESSION information in the URL due to a potential issue.
    I have a feeling the requirement is to remove the JSESSION data from the response content but I should know more this afternoon. I've never messed with stream profiles so this would be a first.
    Thanks,
