pvaughan's avatar
pvaughan
Nov 20, 2013
Need help with Irule to redirect based on http path or host header
I need to create an irule that will redirect traffic to a different pool bassed on the following criteria. The http path begins with /socket.io OR ((The http header 'Upgrade' contains the string 'WebSocket') AND (the http header 'Host' begins with 'ws')). This is what I have so far, any help is appreciated.
 Assign a pool HTTP path
    switch -glob [string tolower [HTTP::path]] {
        "/socket.io*" {
         select the pool
            pool poolA
elseif HTTP::request {
    switch -glob [string tolower [http_host]] contains { "
  • Just going to the page via internet explorer. When I go to the main page with no uri I get nothing back. So none of the conditions should match and I should be sent to the default pool. Works fine before I put the irule in.
  • Is it a SSL traffic ? If yes are you doing SSL termination on your BIG-IP ?
    Otherwise, could you add a pool assign condition to your last line in order to check if it matches your iRule.
  • It is SSL traffic and it is being terminated on the LTM. I'm not following you on the pool assign condition.
  • Sorry, I made a mistake using the word condition.
    What I suggested to you is to add this at the end of your iRule
    Otherwise use default pool
    pool your_poolname
  • You can add an else but it's not mandatory because it's your last order in your iRule.
  • New irule still doesn't work, same as before. Going to try support. Thanks
    Assign a pool HTTP path matches
     if { [string tolower [HTTP::path]] starts_with "/socket.io*" } {
        pool pl_vantage-beta_1337
    Or if header string matches
    } elseif { { [HTTP::header "Upgrade"] contains "WebSocket" } && { [string tolower  [HTTP::host]] starts_with "ws" }} {
        pool pl_vantage-beta_1337 }
        pool pl_vantage-beta_http
