Blue_whale's avatar
Blue_whale
Jan 08, 2024
Need help on syslog cli configuration
Hello team ,
I have to correct the syslog config with below commands , will there be any impact of running the below commands , Which list commad I can run to perform pre-checks and how to confirm if the configuration working correctly post implementation ?
what is the use of both the commands ?
tmsh modify sys syslog {include "destination remote_server {tcp(10.10.10.8 port (1528));};filter f_alllogs {level (debug...emerg);};log {source(local);filter(f_alllogs);destination(remote_server);};options {use_fqdn(yes); keep_hostname(yes);};"
tmsh modify sys syslog {remote-servers replace-all-with {remotesyslog1 {host 10.1.20.1 local-ip 192.168.101.1 remote-port 5528} remotesyslog2 {host 10.2.20.1 local-ip 192.168.101.1??? remote-port 5528}}}
