Need help on F5 automation to read the irules attached t all the virtual servers
HI team,
I am new tp F5 automation. I am working on script to check irules attached on all of my vips. output should be as below irules
vip_name irule1 irule2 vip1_name irule1 irule2
This is tested with Python 3.4.3 and BigIP 12.1. Did not have 12.0 installation readily available, but it should work the same for you
from f5.bigip import ManagementRoot Optional: omit unsecure certificate warnings from output import requests from requests.packages.urllib3.exceptions import InsecureRequestWarning requests.packages.urllib3.disable_warnings(InsecureRequestWarning) API_ROOT = ManagementRoot("bip-01", "admin", "admin") VSERVER_COLLECTION = API_ROOT.tm.ltm.virtuals.get_collection() for vserver in VSERVER_COLLECTION: print(vserver.name) Catch an error to avoid a VS with no iRules breaking the script prematurely try: irules = vserver.rules except AttributeError: print('- No iRules on this Virtual Server!') else: for rule in vserver.rules: print('-', rule)Output in test env:
$ python list_irules.py vs_0.0.0.0_any - No iRules on this Virtual Server! vs_test_80 - /Common/ir_do_nothing - /Common/ir_do_nothing_again vs_test_443 - /Common/ir_do_nothing - /Common/ir_do_nothing_againAs you can see from the script above, this takes a bit of testing to get the iRules listed. Ofcourse, ideally either the API or SDK should return an empty list if there are no iRules on a Virtual Server, rather than a script-breaking "AttributeError: 'f5.bigip.tm.ltm.virtual.Virtual'>' object has no attribute 'rules'". SDK is a build up on top of a problematic API, so eventually this problem should be addressed by the API developers.
- Hannes_Rapp_162
Nacreous
- jasvinder_singh
python sdk
- Hannes_Rapp_162
Nacreous
I see you already marked it as an accepted answer. Thx but normally you should do it after your question/problem has a working solution. If it just contributes to discussion and is useful, but not the actual solution, use the UP vote.
Anyway. Forgot to ask what is your BigIP version? I'll provide a working solution for 11.5.4 (most popular now) if you do not specify otherwise some time later today
- jasvinder_singh
- Hannes_Rapp
- jasvinder_singh
python sdk
- Hannes_Rapp
- jasvinder_singh
- jaikumar_f5
Noctilucent
A simple tmsh script should give you the output,
tmsh list ltm virtual all rulesOutput will be like below,
ltm virtual VIP1 { rules { Irule1 Irule2 } } ltm virtual VIP2 { rules { Irule3 } } ltm virtual VIP3 { rules none } ltm virtual VIP4 { rules { http2https } } - jasvinder_singh
@jaikumar_f5
DO let me know how to input bigip ip address and credentials
- jaikumar_f5
Noctilucent
I had provided a bash script, which is to be run inside the F5 console itself. If you are looking for python sdk, other folks can help you out.
If your intention is to get the output, why not use a simple BASH, is there any specific reason you're looking for python sdk.
- jasvinder_singh
@jaykumar_f5 i tried this. It seems to give input but not the exact output like
vip1 - irule1 irule2
vip2 irule1 irule2
my exact requirements is to know how many vip's have one particular vip attached {code}
!/usr/bin/pythonfrom import BigIP import requests from requests.packages.urllib3.exceptions import InsecureRequestWarning requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
Connect to the BigIPbigip = BigIP("hostname", "username", "password")
Get a list of all pools on the BigIP and print their name and their members' namefor virtual in bigip.ltm.virtuals.get_collection(): virt = bigip.ltm.virtuals.virtual.load(partition=virtual.partition, name=virtual.name) rule=virt.rules for rule in rules: print "Partition: %s Virtual: %s rule: %s" % (virtual.partition, virtual.name, rule.name) {code}
- Joel_Breton
Hi
You mentioned "my exact requirements is to know how many vip's have one particular vip attached {code}"
Do you mean you need to know how many vip's are using a particular iRule? If so you can add a for loop with the code provided earlier to accomplish this
from f5.bigip import ManagementRoot Optional: omit unsecure certificate warnings from output import requests from requests.packages.urllib3.exceptions import InsecureRequestWarning requests.packages.urllib3.disable_warnings(InsecureRequestWarning) API_ROOT = ManagementRoot("bip-01", "admin", "admin") VSERVER_COLLECTION = API_ROOT.tm.ltm.virtuals.get_collection() IRULE_COLLECTION = API_ROOT.tm.ltm.rules.get_collection() for rule in IRULE_COLLECTION: count = 0 print('iRule Evaluated: ', rule.name) for vserver in VSERVER_COLLECTION: print(vserver.name) Catch an error to avoid a VS with no iRules breaking the script prematurely try: irules = vserver.rules except AttributeError: print('- No iRules on this Virtual Server!') else: for vs_rule in vserver.rules: if vs_rule == rule.fullPath: print(' ', virtual.name) count += 1 print('iRule: ', rule.name) print('Used: ', count)Output should look similar to this
iRule Evaluated: _sys_https_redirect app1_vs virtual server using the irule app2_vs virtual server using the irule iRule: _sys_https_redirect iRule with count Used: 2Hope this helps
