Need help: iRules to allow only URIs
I would appreciate if some one could help me in create iRule/datagroup and applying iRule to allow only few URI's and remaining all should go to invalid page.
https://Ind-hyd.vidya.com/KURservlet/servlet/KURServlet https://Ind-hyd.vidya.com/KURservlet-stage/servlet/KURServlet https://Ind-hyd.vidya.com/KURservlet-test/servlet/KURServlet
All other request should be sent to the below error page: https://Ind-hyd.vidya.com/error/invalid.html
- stan_piron
Cumulonimbus
The previous irule must generate cyclic redirect as the else statement redirect to the same URL.
the following irule must answer the need:
when HTTP_REQUEST { switch -glob [string tolower [HTTP::path]] { switch -glob [HTTP::path] { "/KURservlet/servlet/KURServlet*" - "/KURservlet-stage/servlet/KURServlet*" - "/KURservlet-test/servlet/KURServlet*" {} default { HTTP::redirect noserver "https://Ind-hyd.vidya.com/error/invalid.html } } }The commented line is if you need to ignore the case. if you use this line, all conditions must be changed to lowercase.
