Need help in Big-ip Upgradition
Hello all i have An 6900 RMA unit which has TMOS v9.x. and i want to upgrade it to 11. So can someone please tell me how do do that step by step. Its urgent
- Sec-Enabled_658
There is no step by step for a version 9 to version 11 upgrade. You need to upgrade to version 10.x first, (10.2.4) Then upgrade to 11.x Note: Because your jumping two major versions, there is many risks and caveats that need to be addressed and thought about.
- Kevin_Stewart
Employee
You'll need to do this in stages, from 9.x to 10x,
and then from 10x to 11x
If, however, you want to do a clean installation:
http://support.f5.com/kb/en-us/solutions/public/13000/100/sol13117.html
- DeepakK_154002
Thanks for your help. I would follow this procedure.
