Albert__Tase_70's avatar
Albert__Tase_70
Jan 10, 2007
need help converting the las part of the rue to 9.x
else if (client_addr == 64.191.196.54 netmask 255.255.255.0) {
use pool demo
else {
use pool Java
on the wiki it uses when but would n't that start a new rule I need this in the elseif status the begining of the rule uses when http request.
Al Tase
  • With your iRule I'm assuming you want to use pool demo for all addresses in the 64.191.196.* subnet. If that is the case this should do it:
    } elseif { [IP::addr [IP::remote_addr]/24 equals 64.191.196.0] } {
      pool demo
      pool Java
    -Joe
