Christopher_Boo
Jun 05, 2012Need help combining 2 irules
I'm not much of a scripter but I usually figure it out of I stare at it long enough. I'm trying to combine the 2 irules below. I'd like to insert irule 2 at the end of irule 1. The idea is to allow anyone on the network to hit the specified URIs and be directed to the rec.utt.pool, but to only allow internal users (api.network.list class) to go to the api.utt.pool and either drop or provide an http access denied message to everyone else. I'd appreciate any help.
Thanks,
Chris
Irule 1
switch -glob [string tolower [HTTP::uri]] {
"/pss-alerts*" -
"/pss-forms*" -
"/pss-reports*" -
"/pss-messaging*" {
pool rec.utt.pool
default {
pool api.utt.pool
Irule 2
when CLIENT_ACCEPTED {
if { [class match [IP::client_addr] equals api.network.list] } {
pool api.utt.pool
drop
- Christopher_Boo
I'm now down to 1 error.
error: line 10: [undefined procedure: else] [else]
"/pss-alerts*" -
"/pss-forms*" -
"/pss-reports*" -
"/pss-messaging*" {
pool rec.utt.pool
} elseif { [class match [IP::client_addr] equals api.network.list] } {
pool api.utt.pool
discard
} - nathe
Cirrocumulus
Christopher,
elseif needs an if so I'd say that was the issue. Try changing elseif to if and you shouldn't need an else either.
Hope this helps.
N - Christopher_Boo
Thanks! I tried that and it still gave me an error. I've removed the default bit at the end of the first irule and put an else discard at the end of the second irule. This at least has me functional, though still using 2 irules.
Chris - Richard__HarlanHistoric F5 AccountTry the following I changed it up a little
First I check the IP address, if match send to pool and drop out of the iRule. If not match fall through to the switch statement. If there is no match send a reset and move on.
pool api.utt.pool
return
"/pss-alerts*" -
"/pss-forms*" -
"/pss-reports*" -
"/pss-messaging*" {
pool rec.utt.pool
default {
reject
} - Christopher_Boo
The problem with this is I want the users on the api.network.list to have access to those URIs for the rec.utt.pool as well. Thanks for the input!
Chris - Richard__HarlanHistoric F5 AccountOk it then this should work I had to double the switch statement but it allows if the ip matches and the URI matches it will goto rec.utt.pool ulse api.utt.pool
"/pss-alerts*" -
"/pss-forms*" -
"/pss-reports*" -
"/pss-messaging*" {
pool rec.utt.pool
default {
pool api.utt.pool
"/pss-alerts*" -
"/pss-forms*" -
"/pss-reports*" -
"/pss-messaging*" {
pool rec.utt.pool
default {
reject
} - nathe
Cirrocumulus
Just refreshed the screen to post my suggestion and Richard had beaten me to it ;-)
Think a curly brace is missing. Here's mine anyway:
if { [class match [IP::client_addr] eq api.network.list] } {
"/pss-alerts*" -
"/pss-forms*" -
"/pss-reports*" -
"/pss-messaging*" {
pool rec.utt.pool
default {
pool api.utt.pool
if { [class match [IP::client_addr] ne api.network.list] } {
"/pss-alerts*" -
"/pss-forms*" -
"/pss-reports*" -
"/pss-messaging*" {
pool rec.utt.pool
default {
reject
At least we're both on the same page!
N - Christopher_Boo
That sure looks like it will do the trick. Thanks so much to both of you!
Chris
