Ted_Kircos_1126's avatar
Ted_Kircos_1126
Nov 24, 2006
Need help - Before i pull my hair out!!!
Getting the following trying to add the irule below... Im stumped... Anyone see whats wrong or how to fix it?
line 8: [undefined procedure: http://] ["http://" + [HTTP::header "AP_LOCHOST"]]
line 9: [wrong args] [set replace "https://" + [HTTP::header "AP_LOCHOST"];]
when HTTP_RESPONSE {
if { [HTTP::status] starts_with "3" } {
set location [HTTP::header "Location"];
if { $location != "" } {
if {[HTTP::header "AP_NO_SSL_REDIR"] == "" } {
set find ["http://" + [HTTP::header "AP_LOCHOST"]];
regsub $find $location $replace newlocation ;
HTTP::header replace $location" newlocation;
return;
  • hoolio's avatar
    hoolio
    Sorry... the format for string map is:
    set my_new_string [string map {$find1 $replace1 $find2 $replace2} $original_string]
    You can specify just one pair of find/replace strings if you want.
    If you wanted to minimize the steps, you could use something like this:
       if { [HTTP::status] starts_with "3" and [HTTP::header "Location"] != "" and [HTTP::header "AP_NO_SSL_REDIR"] == ""} {
          HTTP::header "Location" [string map { [concat "http://"[HTTP::header "AP_LOCHOST"]] [concat "https://"[HTTP::header "AP_LOCHOST"] } HTTP::header "Location" ]
    Note that I didn't actually test this, but I think it matches the gist of what you're trying to do.
    If you run into problems, try updating the longer version and check the logging in /var/log/ltm to see where it's failing.
    Aaron
  • i am getting the following in the logs
    Nov 28 13:44:23 tmm tmm[710]: Rule dev1.clarica.com_https-irule : Status: 302
    Nov 28 13:44:23 tmm tmm[710]: Rule dev1.clarica.com_https-irule : location: https://dev1.clarica.com/bcheck.html?redir=/e/signin/index.asp
    Nov 28 13:44:23 tmm tmm[710]: Rule dev1.clarica.com_https-irule : find: http://
    Nov 28 13:44:23 tmm tmm[710]: Rule dev1.clarica.com_https-irule : replace: https://
    Nov 28 13:44:23 tmm tmm[710]: 01220001:3: TCL error: Rule dev1.clarica.com_https-irule - can't read "original_string": no such variable while executing "string map {$find1 $replace1 $find2 $replace2} $original_string"
    with the follow irule
    log local0. "Status: [HTTP::status]"
    log local0. "location: $location"
    set find [concat "http://" [HTTP::header "AP_LOCHOST"]]
    log local0. "find: $find"
    set replace [concat "https://" [HTTP::header "AP_LOCHOST"]]
    log local0. "replace: $replace"
    log local0. "newlocation: $newlocation"
    HTTP::header replace $location $newlocation
    log local0. "replaced location header"
  • I believe hoolio meant for the following to be a format example, not an actual line in your code.
    In other words, just change the "set newlocation" line as it was originally typed (or, rather, in your current rule replace the line above with the line below) to:
    set newlocation [string map {$find $replace} $location]
  • Deb_Allen_18's avatar
    Deb_Allen_18
    Historic F5 Account
    Did you ever get this to work...?
    Using that approach, I'm finding that the variables within the map {} are not expanding.
    thanks!
    /deb
  • I have tried a number of options but I cannot get variables to work in the mapping section....
    Has anyone solved this.... or knows how to make it work.
  • Here is my working copY!
    if {$location != "" } {
    set find "http://"
    append find [HTTP::header "AP_LOCHOST"]
    append replace [HTTP::header "AP_LOCHOST"]
    set newlocation [string map [list $find $replace] $location]
    HTTP::header replace "Location" $newlocation
  • Thanks for the last piece of the puzzle.... it was the "list" function that solved my problem.
    if {[HTTP::is_redirect]}{
    set find ":25620/"
    set replace "/"
    set location [HTTP::header value Location]
    HTTP::header replace Location [string map [ list $find $replace] $location]
    log [string map [ list $find $replace] $location]
    log [string map { ":25620/" "/"} $location]
    Jan 30 10:23:51 tmm tmm[1385]: 01220002:6: Rule lng-ln-cert-certlexisgw.lexis.com-http : http://certlexisgw.lexis.com/hbeat/
