Kevin_Nail's avatar
Kevin_Nail
Jul 12, 2021
need a way to get the DEFAULT cipher string via a yaml script
Im writing a yaml script to get the DEAULT cipher string being used.
Here is my speciic code section:
block:
    - name: check the default cipher
     bigip_command:
      commands:
      - tmm --clientciphers DEFAULT | grep -i {{ cipher_string}}
      provider: "{{ provider }}"
     delegate_to: localhost
     register: cipher_out
     ignore_errors: true
   when: software_version_out.stdout != '15.1.4.1'
This is the error I get:
TASK [check the default cipher] **************************************************************************************************************************************************************
[WARNING]: Using "write" commands is not idempotent. You should use a module that is specifically made for that. If such a module does not exist, then please file a bug. The command in
question is "tmm --clientciphers DEFAULT | grep -i de..."
Is there another way to get this information via tmsh?
