Multi-Domains mapped to single IP
Hi ALL, we have three domains , 1- domain1.hostname.com 2-domain2.hostname.com 3- domain3.hostname.com all mapped to single IP "VIP: 10.10.10.10" when I access domain1.hostname.com, it should give me different page than domain2 and domain3, but it doesn't happen all time I get the same page.
before the F5 the backend server was able to deal with the request if it was domain1 gives him a page if the request was domain2 it gives him another page and so on.
I want to know how to solve the problem from F5 although the difference is the only hostnames, and the path doesn't change. also have a question, when F5 forwards the request to back-end server it doesn't includes the domain name at all??
by default host header is not changed. you can run tcpdump/ssldump on bigip to check.
- nitass
Employee
- refra_151287
Cirrus
I'm a little confused I have domain1.hostname.com when I access it resolves the name to IP which is 10.10.10.10 , then sends the request with destination IP 10.10.10.10 the hostname doesn't exist in the HTTP packet, Is that right??? - nitass
Employee
what are you tying in browser? is it domain1.hostname.com or 10.10.10.10? if domain1.hostname.com, http host header will be domain1.hostname.com. - refra_151287
Cirrus
then the resolve just get the destination IP, but the header doesn't change at all, if issued domain1.hostname.com, the hostname in the header is "domain1.hostname.com", OK fine. could you please provide me with the command I can see clearly the domain in the header to BE server fron F5, I used something as following: tcpdump -i 0.0 -X host and port 80 ------> changed the Monitor to ping, but without getting something clear!
- nitass_89166
Noctilucent
- refra_151287
Cirrus
I'm a little confused I have domain1.hostname.com when I access it resolves the name to IP which is 10.10.10.10 , then sends the request with destination IP 10.10.10.10 the hostname doesn't exist in the HTTP packet, Is that right??? - nitass_89166
Noctilucent
Cirrus
- nitass
Employee
try this.
ssldump -Aed -nni 0.0 host x.x.x.x and port 80 x.x.x.x is server ip - refra_151287
Cirrus
the command is cleared the Host at the request for port 80 but for 443 didn't! I wasn't able to find out the Hostname.
- nitass
Employee
for https, you have to use private key to decrypt it. ssldump -Aed -nni 0.0 -k host x.x.x.x and port 443 - refra_151287
Cirrus
Private key if I'm using the default self signed certificate between the F5 and server "serverssl" what will gonna be private key? - nitass
Employee
it is server-side (between bigip and server), isn't it? private key should be from the server.
