becabatcb_30511's avatar
becabatcb_30511
Apr 25, 2017
Move VIPs away from iApp or disable iApp from modifying certain VIPs.
All,
Hello. I have a question regarding iApp and moving iApp VIPs away or disabling iApp from modifying certain iApp-created VIPS. After using iApp for the first time to create some HTTP and TCP VIPs, we decided that we rather use the traditional F5 GUI to manage them.
Is there anyway to "disable" iAPP from modifying these VIPs as we have customized them through the traditional GUI and do not want iApp to reset back to iApps config state.
If not, is there anyway to migrate/recreate these VIPs with minimal work?
Thank you.
