CX_280703
Jun 16, 2017Move APM Policy flow to a Macro
Hi there,
In the VPE I know you can move around policy items and flows but how can you move a flow into a Macro, e.g. I want a big policy flow out of the way and into a macro and just reference the macro. Possible?
- Jad_Tabbara__J1
Hello CX,
I don't think it is possible to move a branch from the principal VPE to a Macro.
You will need to copy elements in your principal VPE to your macro by adding block by block and one by one.
Then you can add the newly created macro to the principal VPE.
Regards
