Jonathan_388819's avatar
Jonathan_388819
Apr 18, 2019
monitoring Big-IP memory with PRTG
Hi, I would like to use PRTG to monitor Big-IP memory usage. I imported the F5 mibs but there are 2 types of memory OIDs:
  1. sys host memory
  2. sys multi host other memory
Both OIDs give different readings. Could someone please explain the difference between the two and which one should I use?
Thanks, Jonathan
