vaibhav's avatar
vaibhav
Jul 09, 2012
Monitoring applications on F5
I would require your help ,I have one scenario in which URLs are assigned with http/https monitors and as the IIS services goes down on the servers the monitors mark all the pools down.
As this is a single server hosting multiple application how i can customize the monitors so that if a particular application goes down then only it should mark down the members.
  • have you tried to create a number of pool, i.e. one per virtual host, and configure with its own health monitor? the health monitor can be configured with host header in send string.
    sol2167: Constructing HTTP requests for use with the HTTP or HTTPS application health monitor
    http://support.f5.com/kb/en-us/solutions/public/2000/100/sol2167.html
  • Hi Nitass thanks for the quick response.....
    Now updates all my virtuals have different pools assigned to them and from the my prospect if i have individual pools and individual monitors assigned to that pool it should only see the response for the particular application.
    It can not harm other services ,so can you please help me to know one this is IIS down is global to a server or its unique for individual application instance.
  • Ya monitor assigned is same but all pools and virtual's are different having different IPs
  • from the my prospect if i have individual pools and individual monitors assigned to that pool it should only see the response for the particular application. does http host header help?
    so can you please help me to know one this is IIS down is global to a server or its unique for individual application instance.i do not know how the iis is configured. anyway, if service port is not running, it would affect all application.
  • I got it now :) what you were trying to tell me ...all makes sense now ....thanks alot nitass..........
  • And ya Http host header will be the right choice here :)..thanks
