Monitor with HTTP method
Hello, I am trying to do a simple HTTP GET, this is my Send string: GET /ImagesProvider.svc/ensureready HTTP/1.1\r\n
the HTTP Method replies with 500 when not ready and 200 when ready. I added "200" to my Receive String and i can't see my pool as up although with SoapUI i do get 200 on the above Send String. I also tried "Ok" with no luck. any idea what am i missing here?
thanks, Shlomi.
- nitass_89166
Noctilucent
can you try this one?
GET /ImagesProvider.svc/ensureready HTTP/1.1\r\nHost: \r\nConnection: Close\r\n\r\nsol2167: Constructing HTTP requests for use with the HTTP or HTTPS application health monitor
https://support.f5.com/kb/en-us/solutions/public/2000/100/sol2167.htmlI added "200" to my Receive String and i can't see my pool as up although with SoapUI i do get 200 on the above Send String. I also tried "Ok" with no luck.
you may try tcpdump.
e.g.
tcpdump -nni 0.0:nnn -s0 -w /var/tmp/output.pcap host x.x.x.x and host y.y.y.y and port zzz -v x.x.x.x is non-floating self ip on server vlan y.y.y.y is server ip zzz is server port- shlomi_133455
still doesn't work, i tried what you did and also tried it with the host ip, nothing... where do i run this tcpdump from ?
- nitass
Employee
e.g.
HTTP 1.1 requires a Host: header along with a double CRLF at the end of the request.
