Monitor status for 11.2.1
kindly i need from the QKview to figure out which health monitor is available, my system is running 11.2.1, so the /var/lo/ltm is not useful here, thanks in advance!
- Michael_Jenkins
Have you tried uploading it to iHealth and seeing if you can find what you're looking for there?
- SynACk_128568
are you looking for monitors which are currently in use or which are available on the bigip ?
- refra_151287
Cirrus
for monitors applied at specific pool.
- SynACk_128568
- dragonflymr
- SynACk_128568
Not sure if i got the question if you are looking for monitor applied by you for monitoring your backend applications .
b pool list | grep monitor ---> this should give you monitor applied at pool level
I hope this you were asking for .
Regards
- refra_151287
Cirrus
thanks for your replay, I have pool with 3 health monitors if any one goes down. the whole pool goes down, at 11.2.1, I can see which health monitor made the that pool down, at 11.4.1 and later, i can see it from /var/log/ltm clearly, so I'm asking about a way find which health monitor made the pool down. kindly let me know if you need more clarification. - SynACk_128568
Okay then Piotr has send link above , it might be useful ....
