Monitor Receive String question
HTTP/1.1 200 OK
Cache-Control: private
Content-Type: text/html; charset=UTF-8
Content-Encoding: gzip
Content-Length: 11695
Connection: Keep-Alive
Keep-Alive: timeout=5, max=999
Server: Oracle-Application-Server-10g/10.1.2.0.2 Oracle-HTTP-Server OracleAS-Web-Cache-10g/10.1.2.0.2 (N;ecid=360991800642,0)
Date: Wed, 28 Sep 2011 14:42:55 GMT
Content-Location: /servlet/page
Can i put any of those strings in the Receive String field?
I tried to put "gzip", "oracle-application-server", "servlet" and the monitor marks the pool down.
The ones that worked were: "oracle" and "server"
All of them without quotes.
Any ideias?
Thanks.
- hoolio
Hi Thales,
Your monitor send string probably isn't setting an accept-encoding header so the server won't respond with gzip compressed content. So the monitor marks the server down. The servlet string is probably only found when the server is redirecting the client using the Content-Location header.
Is there a reason you don't want to look for an HTTP 200 response to mark the the pool members up? You could use this to support HTTP 1.0 or 1.1 responses with a 2xx status:
HTTP/1\.(0|1) 2
Aaron - Thales_92506
Aaron, i tried to put 200 OK, but the monitor marked an ok pool member down.
the rest of the response from the server is like this:
.............r.H..U..^.&..1 c...S2`[^n.Jf.SST..P"$...{..1[.0U.....s.%[email protected],;....W.C...........7M..?.a.....p...f`.....lj{8./..:3.X......}..W........3.7[..?8,.1.........yn..
..7.4e......bC5...f./..(8/.'.;a....}Soe...a.8..i6`...!...?D....gZ.{i4.W.0\..1p....T|....D==+..........k.$.Y.\:]....
What would you suggest for the receive string?
Thanks! - Thales_92506
Figured this out.
Thanks - OM
Altocumulus
Hello,
sorry for posting this here, cause I'm unable to create a new post...
I have 2 Big-IP 3600 (LTM/ASM) modules configured in Active/Standby mode. The standby device is sending Keepalive monitoring health-check to my pools, is this a normal behavior? Is there any way to force only active device monitoring the pools?
I have the 10.2 software installed.
thank you. - nitass
Employee
is this a normal behavior?it is normal. unit still does health check even it is on standby.
for keep-alive, i understand if we use connection: close in health monitor send string, connection won't be keep-alive.
sol3224: HTTP health checks may fail even though the node is responding correctly
http://support.f5.com/kb/en-us/solutions/public/3000/200/sol3224.html
