Monitor question: 302 after login on Solarwinds Orion
I'm trying to write a health monitor (LTM 11.4.1 HF2) for the Solarwinds Orion web interface where I'm passing login credentials in the URI portion of the GET which looks like this:
GET /Orion/Login.aspx?AccountID=username&Password=password
Upon success of that, the IIS server sends back a 302 redirecting to another URI (/Orion/SummaryView.aspx?ViewID=1). My health monitor doesn't seem to work no matter what receive string I look for. If I have it look for content in the second URI, it fails. If I have it look for "Object moved" in the first URI, it fails. My send string looks like this:
GET /Orion/Login.aspx?AccountID=username&Password=password HTTP/1.1\nHost: hostname.fqdn\r\nConnection: close\r\n\r\n
If anyone has any experience with Solarwinds (or similar 302 redirects after login) send and receive string monitors, I'd certainly appreciate any pointers.
Thanks in advance, Roy
- nathe
Cirrocumulus
Roy, the receive string when monitoring a client with a redirect should be something on the redirect page. I see you've tested this and it doesn't work.
Have you tried running Curl from the f5 to see what is being returned on the redirect page?
Rgds
N
- roykidder
Yes, the redirect page returns:
Object moved
Object moved to .Prior to realizing there was a redirect, I looked for the string "Orion Summary Home" which is content from the page the browser is redirect to. Then I tried "Object moved" for the receive string yet the monitor still failed.
Thanks, Roy
- nathe
Cirrocumulus
Roy,
Two things, I'd change the monitor to a HTTP 1.1 one, as default f5 health monitors are v0.9.
So something like this:
GET /Orion/Login.aspx?AccountID=username&Password=password HTTP/1.1\r\nHost:\r\nConnection: Close\r\nAccept: /\r\n\r\nHopefully my syntax is correct here.
Also, take a look at the following link as it may help Troubleshooting Health Monitors
Hope this helps,
N
