monitor probing when pool member is manually marked down
Will LTM send monitoring probes to the pool member when it is manually disabled by the user?
Awaiting for your response. Parvez
- parvez_70211
In other words will LTM check pool members availability even when the member is marked down manually on the LTM.
- nathe
Cirrocumulus
parvez,
Yes it should do. The big-ip will still need to know whether it's available when manually marked back up.
N
- parvez_70211
Thanks Nathan.
Had one more query.
I have two files bigip.conf and bigip.conf.bak.
When the LTM is reloaded, which of these files will be loaded into the running config of the box?
what is the use of .bak file?
Regards, Parvez
- nathe
Cirrocumulus
.bak is just a backup file. The bigip.conf is the main file.
