rodrigo_Benzaqu
20 years agoMonitor help on 4.5
Hi Guys, I´m crating a monitor on my Bigip that monitor http://listado.mercadolibre.com/testeo .
Do you know if that is possible ?
I´mean , I have a pool of Application servers with 172.16.0.X Ips. And my monitor is monitoring http://172.16.0.X/testeo.
I need that my monitor pool http://172.16.0.X/testeo sending the Host: listado.mercadolibre.com.ar
That will help my problem.
Somebody knows if is this possible ?
Thanks in advance
Rodrigo
- Colin_Walker_12Historic F5 AccountWe here at DevCentral are the folks who work on the API (iControl) and the onboard packet inspector/scripting language (iRules). If you have a question about building iControl apps or writing iRules, this is the place for you.
Unfortunately, this isn't the place for product technical support. We simply aren't staffed to handle that side of things. You'll need to talk to the folks in our product support department for questions like these.
They can be easily contacted here: Click here - https://websupport.f5.com/csp/logon.asp
A good place to start looking for information is often Click here - http://tech.f5.com/askf5/jsp/combined/index.jsp
Colin
