DNSgeek_90802's avatar
DNSgeek_90802
Dec 28, 2009
modifying HTTP::uri not working?
I have an irule that needs to modify the URI of a request before it passes it to a pool of squid servers. What I have is:
      if { $::DEBUG }{
           log "requri -> '[string tolower [HTTP::uri]]'"
      HTTP::uri [string trimright [HTTP::uri] ".html"]
      if { $::DEBUG }{
          log "newuri -> '[string tolower [HTTP::uri]]'"
What I see in the logs is:
  Dec 28 11:36:00 local/tmm info tmm[2790]: 01220002:6: Rule myrule : requri -> '/blah.html'
  Dec 28 11:36:00 local/tmm info tmm[2790]: 01220002:6: Rule myrule : newuri -> '/blah.html'
So, The .html isn't being trimmed. Any idea why?
Thanks!
Tom
  • Hi Tom,
    Have you tried removing the " " on your string trim?
    Bhattman
  • Ok, I just tried that:
          if { $::DEBUG }{
               log "requri -> [HTTP::uri]"
          HTTP::uri [string trimright [HTTP::uri] .html ]
          if { $::DEBUG }{
              log "newuri -> [HTTP::uri]"
      Dec 28 13:24:14 local/tmm info tmm[2790]: 01220002:6: Rule myrule : requri -> '/blah.html'
      Dec 28 13:24:14 local/tmm info tmm[2790]: 01220002:6: Rule myrule : newuri -> '/blah.html'
    So the .html still isn't being trimmed.
  • hoolio's avatar
    hoolio
    Most of the HTTP:: command values are cached in the same event of the same priority. See this post for details and a few options:
    Manipulate a HTTP:path then continue to parse iRule
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=813133&ptarget=813134
    Aaron
  • So I changed my code to read:
         set myuri [HTTP::uri]
         if { $::DEBUG }{
              log "requri -> $myuri"
         set myuri [string trimright $myuri .html ]
         if { $::DEBUG }{
             log "newuri -> $myuri"
    Now the trimming seems to be having as expected. Thanks.
  • hoolio's avatar
    hoolio
    You haven't actually set the URI to the new value though. If you just want to log the update, you could use this:
     when RULE_INIT {
        set ::DEBUG 1
          if { $::DEBUG }{
               log local0. "Original URI: [HTTP::uri]
          HTTP::uri [string trimright [HTTP::uri] .html]
     when HTTP_REQUEST priority 501 {
         This event runs after the prior HTTP_REQUEST event at the default priority of 500
         Remove or comment out this event once done testing
        if { $::DEBUG }{
           log local0. "Updated URI: [HTTP::uri]
    Aaron
  • hoolio's avatar
    hoolio
    Actually, string trimright won't work as you're expecting. It's not doing a replacement of .html--it's looking for any instance of any character in .html and removing it from the URI:
    % string trimright /testtttt.html .html
    /tes
    If you want to remove .html from the URI, you could use string map:
    % string map {.html ""} /testtttt.html
    /testtttt
    or for your iRule:
    HTTP::path [string map {.html ""} [HTTP::path]]
    Note that HTTP::path is the URI minus the query string. Assuming you only want to replace .html with nothing in the path this would be more precise.
    Aaron
  • Ok, I changed it to be:
         set mypath [HTTP::path]
         if { $::DEBUG }{
              log "reqpath -> $mypath"
         set mypath [string map {.html ""} $mypath]
         if { $::DEBUG }{
             log "newpath -> $mypath"
         if { ! ($mypath ends_with "/") }{
             set mypath $mypath/
             if { $::DEBUG }{
                 log "apppath -> $mypath"
         HTTP::path $mypath
         pool A
