RiverFish's avatar
RiverFish
Jan 06, 2017
Modify script to allow more than one variable (pool).
This iCall script works great, but you can only add one variable (one pool name). Therefore, I have to create a separate script for each pool I want to check, which is not desirable. I need help finding the best way to modify the script so that multiple pool names can be added. That way I can have just the one script that checks multiple pools.
admin@(f5-device-001)(cfg-sync Standalone)(/S1-green-P:Active)(/Common)(tmos) list sys icall script check-members-script
sys icall script check-members-script {
    app-service none
    definition {
        set pn "/Common/pool-fooapp.example.com"
        set total 0
        set usable 0
                foreach obj [tmsh::get_status /ltm pool $pn detail] {
                    puts $obj
                    foreach member [tmsh::get_field_value $obj members] {
                        puts $member
                        incr total
                        if { [tmsh::get_field_value $member status.availability-state] == "available" && \
                            [tmsh::get_field_value $member status.enabled-state] == "enabled" } {
                                incr usable
            if { [expr $usable.0 / $total] < 0.7 } {
                tmsh::log "Available pool member threshold reached for $pn"
    description none
    events none
  • This appears to be working well:
        app-service none
        definition {
            set pool_names "/Common/pool-fooapp1.example.com /Common/pool-fooapp2.example.com /Common/pool-fooapp3.example.com"
            foreach pn $pool_names {
            set total 0
            set usable 0
                        puts $obj
                            puts $member
                            incr total
                                    incr usable
        description none
        events none
