Zafer_101134
Dec 16, 2010Microsoft cluster implementation problem
Hi All
The customer use Microsoft cluster for IIS.
i can not ping the cluster ip address from bigip except server ip addresses
i opened tcpdump and i can not see ping reply from cluster
i checked the arp info and i can see mac address in to the dynamic arp records
what can be problem reason
regards
zafer
- hoolio
Hi Zafer,
If the response isn't coming back from the server, you could start at the server and work your way towards LTM to see where the reply is dying.
Aaron - Zafer_101134
Hi
we can ping the bigip from the servers
regards
zafer - Chris_Miller
Altostratus
Can you confirm that the cluster IP should actually respond to ping? Have you pinged it successfully from other boxes? - Zafer_101134
Hello
Microsoft Cluster on works on production . we can ping it from everywhere except bigip units.
i found information about Microsoft. Microsoft cluster works on multicast.
i disabled auto last hop
added static arp
enabled multicast ......
but still does not work
you can get info from this link
http://support.microsoft.com/kb/317239
http://support.f5.com/kb/en-us/solutions/public/3000/600/sol3600.html?sr=118
87278
i opened the case from f5 support they told me this is consultancy issue!!! lol
zafer
