Héctor's avatar
Héctor
6 years ago
Merging BIG-IP configuration into the running using tmsh
Hi everyone,
I'm using the following commands via tmsh:
load sys config verify merge file /var/tmp/file.txt with no errors and
load sys config merge file /var/tmp/file.txt
but this does not seem to work. instead of adding the configuration (to add 2 members to an existing pool) this overwrites the existing members with the new ones
Please, any suggestion?
Thanks in advance.
Kind regards.
