kaladhar_48878
Jan 22, 2012MAX SSL connections for LDAP loadbalancing
HI ,
We are planning LADP load balancing on virprion 2400 LTM virtual instance.
I need your help for understanding the Capabilities of LTM instance with respect to SSL connections. Can you please let me know how many maximum SSL client terminations can be handled by each virtual LTM instance.
Please let me know what is the best method to increase the Number of SSL connections for virtual instance .
Thanks in advance.
Kaladhar
- hoolio
Hi Kaladhar,
Are you using vCMP or when you say virtual LTM instance do you mean a virtual server? Also, are you using SSL between LTM and the LDAP servers?
Aaron
