msavani_64338's avatar
msavani_64338
Apr 24, 2009
management IP and self IP in same network
I am not sure if this question is already been asked in this forum.
I am using BIG-IP-10.x and facing issue while configuring self IP address for vlan because it is in same subnet of management IP and receiving below error
BIGpipe self IP address creation error:
01070392:3: Self IP 10.xx.xx.x1 / 255.255.255.0: This IP shares a network with the management IP (10.xx.xx.x2 / 255.255.255.0).
is there any workaround for this?
Thanks,
  • No, the management port must be on a separate network. The reason is that the management port is simply a NIC that uses an address hosted by the Linux kernel; it is not part of the switch fabric. The rest of the ports are controlled by the tmm kernel(s), so they cannot share address space.
    If you don't have a separate management network, then I would just leave mgmt on 192.168.1.245 (assuming you don't use 192.168.1 elsewhere) and configure it through a directly connected laptop. Once you get an address on the switch ports, you can do 99% of the things you need to do in the GUI or CLI from that address (just make sure to leave the default access for port 22 and 443 enabled). About the only thing you really need to be connected to the management port for is to do upgrades.
    Denny
  • hoolio's avatar
    hoolio
    You could potentially configure the SCCP IP address on the same subnet as a switch port. See this post (Click here) for details.
    Aaron
  • Posted By msavani on 04/24/2009 5:40 PM
    Thanks,
  • hoolio's avatar
    hoolio
    Hi Kevin,
    Did you have a question?
    Aaron
  • Hi Aaron,
    I have a question on this subject.
    I'm experiencing the same issues. The Standby Unit won't install configuration from the Active unit (either by a Config Sync or b config install <>).
    BIGpipe unknown operation error: 01070391:3: Admin IP 10.15.xx.x / 255.255.254.0: This IP shares a network with a Self IP.
    Within the Configuration, there isn't a Self IP within the same network as the MGMT IP Address.
    Have you ever encountered this issue?
    Chris
  • Within the Configuration, there isn't a Self IP within the same network as the MGMT IP Address.
    is there route on tmm which covers mgmt subnet?
    • Greenberg's avatar
      Greenberg
      Hi, The MGMT Network is on a /23 but there is a Network Route on TMM which covers this with a /16 network, i.e. MGMT Network 10.1.32.0/23, TMM Route 10.1.0.0/16. Would this be causing the issue?
      Greenberg
      Hi, You were correct. I've "re-subnetted" the Routing Table in TMM to exclude the /23 and it's now working. I've never encountered this before and hopefully the Error Codes are more descriptive in newer versions of the Code. This F5 is running 10.2.3 HF1 but we are upgrading to 11.6 in the near future. It should refer to Routes and NOT Self IPs. Thanks a million for your assistance. Chris
      Greenberg
      Greenberg
  • wani's avatar
    wani
    Hi everyone.
    I want to resolve same problem.
    Can I resolve this problem if tmm interface's self IP is configured with route domain on same management-IP subnet?
    ex.
    management-IP with default route domain 0
      192.168.1.10/24:0
      *of course,not specify route domain.
    tmm self IP with route domain 20
      192.168.1.20/24:20
    I don't have test environment.so please show me if it's possible.
