olivierf_346020's avatar
olivierf_346020
Jan 25, 2018
Management for Viprion
Hello all
We've a VIPRION C2400 with 2 blades,
the master of the blade cluster is blade2,
the management port of the 2 blades are connected to a switch and UP
when i remove - for a test - the cable from the management port of blade 2 the device is not more reachable on the cluster ip address
blade 1 remains accessible with its member indvidual ip
my question :
is this the normal way Viprion blade cluster is working ?
i was expecting a kind of intra-blade failover, blade 1 taking over the cluster ip ?
is this possible ?
Thank you
  • Hello olivierf,
    The failover between the two blades will be in case the primary is down , but in your situation , the primary still up and is handling traffic , only management access is down . So accessing the cluster management will always lead to the primary blade from which you've removed the cable.
