Macaron's avatar
Macaron
Jan 04, 2018
Maintenance page without doing SSL bridging and using HTTP profile
I am trying to host a maintenance page on f5 itself using iFiles but I have been told that I have to do SSL bridging as I am using HTTP profile with the iRule to trigger the maintenance page via iFiles. The problem is our business require traffic to be end to end encrypted for that I am using performanceL4 and after that I am not able to host maintenence page on f5 using iFiles as if I use http profile with perfomanceL4 then it breaks the connection. Is there a way that can be used to host a maintenence page on f5 using iFile. Or the second option we can use an external portal and redirect all packets to that portal without doing SSL bridging. ???
  • The problem is our business require traffic to be end to end encrypted for that I am using performanceL4 and after that I am not able to host maintenence page on f5 using iFiles as if I use http profile with perfomanceL4 then it breaks the connection. Is there a way that can be used to host a maintenence page on f5 using iFile.
    may this be usable?
    // config
    [root@ve13a:Active:In Sync] config  tmsh list ltm virtual bar
    ltm virtual bar {
        destination 172.28.24.10:443
        mask 255.255.255.255
        pool foo
        profiles {
            fastL4 { }
        rules {
            qux
        source 0.0.0.0/0
        source-address-translation {
            type automap
        translate-address enabled
        translate-port enabled
        vs-index 13
    [root@ve13a:Active:In Sync] config  tmsh list ltm pool foo
    ltm pool foo {
        members {
            200.200.200.101:443 {
                address 200.200.200.101
                session monitor-enabled
                state down
        monitor fake
    [root@ve13a:Active:In Sync] config  tmsh list ltm rule qux
    ltm rule qux {
    when CLIENT_ACCEPTED {
      if { [active_members [LB::server pool]] < 1 } {
        virtual sorrypage
    [root@ve13a:Active:In Sync] config  tmsh list ltm virtual sorrypage
    ltm virtual sorrypage {
        destination 0.0.0.0:443
        ip-protocol tcp
        mask any
        profiles {
            clientssl {
                context clientside
            http { }
            tcp { }
        rules {
            sorrypage_rule
        source 0.0.0.0/0
        translate-address disabled
        vlans-enabled
        vs-index 14
    [root@ve13a:Active:In Sync] config  tmsh list ltm rule sorrypage_rule
    ltm rule sorrypage_rule {
      HTTP::respond 200 content "this is sorry page\n" noserver
    // test
    [root@centos1 ~] curl -ik https://172.28.24.10
    HTTP/1.0 200 OK
    Connection: Keep-Alive
    Content-Length: 19
    this is sorry page
    • Macaron's avatar
      Macaron
      Thanks, I see you used when HTTP_REQUEST event in your iRule. The problem is if use this event, than I must have to use HTTP profile with VS which will intern not trigger maintenance page without doing ssl bridging.
      The second option I can utilize is hosting maintenance page on an external server and route traffic to that server in case the VS goes down. Not sure if it is possible without SSL bridging.?
    • nitass's avatar
      nitass
      I see you used when HTTP_REQUEST event in your iRule. The problem is if use this event that I must have to use HTTP profile with VS which will intern not trigger maintenance page without doing ssl bridging.
      there are 2 virtual servers, aren't there? the http profile is in the internal virtual server (i.e. not the external one which is facing users).
    may this be usable?
    // config
    ltm virtual bar {
        pool foo
        profiles {
            fastL4 { }
        rules {
            qux
        source 0.0.0.0/0
            type automap
        vs-index 13
    ltm pool foo {
        members {
                state down
        monitor fake
    ltm rule qux {
        virtual sorrypage
        ip-protocol tcp
        mask any
        profiles {
            clientssl {
                context clientside
            http { }
            tcp { }
        rules {
            sorrypage_rule
        source 0.0.0.0/0
        vlans-enabled
        vs-index 14
    // test
    HTTP/1.0 200 OK
    Content-Length: 19
    this is sorry page
    • Macaron's avatar
      Macaron
    • nitass_89166's avatar
      nitass_89166
      Icon for Noctilucent rankNoctilucent
    • Macaron's avatar
      Macaron
      Worked perfectly fine !!! Thank you
