LTM/GTM same box (VE) - GTM Virtual servers are RED
I have setup a configuration with both LTM and GTM on the same box (VE edition in fact).
LTM Configuration
add a partition with route domain 10 (Partition name = LAB-E) vlan extern = facing clients, that target the VS Extern Self = 10.105.1.5/29 VS SUBNET = 10.105.10.0/24
vlan intern = facing pool members Extern Self = 10.105.1.13/29 SNAT SUBNET = 10.105.11.0/24
Everything is working properly, as exepected.
2 VS so far: 10.105.10.1 = http 10.105.10.2 = ssh
They are working and are green state
GTM Configuration
On the common partition I setup a Self IP that will be my listener. Self IP (Common partition) = 10.101.0.73 I setup the server: Name = lab1.LAB-E IP = 10.105.1.5
the iquery seems OK: [root@f5-lab1:Active:Standalone] netstat -na |grep 4353 tcp 0 0 :::4353 :::* LISTEN
tcp 0 0 ::ffff:10.105.1.5:4353 ::ffff:10.101.0.73:42263 ESTABLISHED
If I check the iqdump everything seems to be got: [root@f5-lab1:Active:Standalone] ssl.crt iqdump 10.105.1.5
11.6.0 big3d Version 11.6.0.0.0.401 linux
192563 108531 84032 26824252 7520616 19303636 0 139013 1 0 notice 0 0 0 0
4 ::ffff:10.105.1.5 :: 1 66 Sun Nov 15 10:42:56 2015 1 ::ffff:10.105.1.5 ::ffff:255.255.255.248 0 66 /LAB-E/Externe_2010 1 ::ffff:10.105.1.13 ::ffff:255.255.255.248 0 66 /LAB-E/Interne_2011 0 ::ffff:10.105.1.1 :: 0 66 2 ::ffff:10.105.10.1 :: 80 0 /LAB-E/VS-ROUGE_virtual 2 ::ffff:10.105.10.2 :: 22 0 /LAB-E/VS-SSH 5 :: :: 0 0
192620 108563 84057 26831847 7522447 19309400 0 139023 1 0 notice 0 0 0 0
I can see both my LTM virtual server.
I do not use Virtual server discovery (and if i do it does not work either) I set up my two Virtual server, on the server I created, and they are systematically red.
I don't know what to check now. Routing seems ok
- Florent_Thieba1
When i set up my server on the gtm (without virtual server configured in it (no Virtual Server Discovery enabled)) ==> It is green.
As soon as I configure a Virtual server on it (exemple 10.105.10.1 which is perfectly working on the LTM) the virtual server + the server are now red
- Florent_Thieba1
When i set up my server on the gtm (without virtual server configured in it (no Virtual Server Discovery enabled)) ==> It is green. As soon as I configure a Virtual server on it (exemple 10.105.10.1 which is perfectly working on the LTM) the virtual server + the server are now red
