LTM SSL Profiles issue
Hi all,
Happy new year.
I have a website hosted on a Windows IIS server and want to publish it with SSL certificate. what are the configuration steps should I do on the F5 ? and what is the profile should I use client or server ? also what are SSL certificates will be added on the F5 by the way I get the certificate.pfx from the web server ?
another question what are the certificates should I add on the F5 if I will use an USB-token to authenticate the clients ?
- nathe
Cirrocumulus
Tamer,
In brief, to terminate the SSL connection you will need a Client SSL Profile configured and applied to the Virtual Server. If you need to re-encrypt to the backend webserver then you would also need a Server SSL Profile configured and applied to the Virtual Server (note, most times the default serverssl profile will work fine).
You will need to export the cert/key from the existing web server, import onto the BIG-IP and associate with the new Client SSL Profile.
Client certificate Authentication will require the Trusted CA certificate configured on the BIG-IP, perhaps a Root or Intermediate CA cert. Normally this would be from an internal PKI. You just configure the Client SSL profile to accept client certs signed from a particular Trusted Authority.
See the following links for more granular help:
Managing SSL certificates for BIG-IP systems using the Configuration utility
Overview of the Client SSL profile
Hope this helps,
N
- Tamer_Ezzat_235
Hi Nathan,
Thanks for your support
So I will import the certificate.pfx file and create SSL client profile only OK that is fine
and for Client certificate Authentication I will add in addition to the above certificate.pfx I will add the Trusted CA certificate Root or Intermediate CA cert.
I will try then and will keep you updated.
One more thing: each website should has a Trusted CA certificate - root CA or not ? should I create a root CA for each website ?
Thanks for your help
- nathe
Cirrocumulus
an intermediate should be fine, whatever has signed the client certificate
- Tamer_Ezzat_235
OK Thanks I will do that and will update you
- tito_110_241800
Hi Nathan,
Thanks so much for your support
It worked
I created a SSL client profile using the certficate.pfx , and created SSL server profile using the default serverssl profile.
Many thanks to you
- nathe
Cirrocumulus
no probs. mark up if happy.
